How to add labels in the new issue view
Michal Kubiak
I'm using Jira Cloud in my team. Recently the issue view on the boards was switched to a new format. Instead of a side pane it shows a new screen. I cannot edit the Labels field on this view. I could do it in the old view. I switched back to the old issue view, but I have a lot of users on this instance who will ask me questions about that. So how can we add labels to issues in the new view?
3 votes
Thomas Schlegel
Hi @Michal Kubiak,
just click on "Show more":
And then you can add labels:
Michal Kubiak
I am able to see the "Labels" field. the problem is I cannot edit it in the new Issue details view. When I switch to the old Issue details view, I can do it. I seems it's not a matter of permissions then.
Thomas Schlegel
Did you test with the same issue in both views? If so, I would contact Atlassian Support with this: https://support.atlassian.com/
Michal Kubiak
Yes, I tested it with the same issue.
Michal Kubiak
I found the problem. The Labels field wasn't added to the view issue screen. There is a bug in Jira that make this field visible and  even editable in the old issue details view, even when it is not configured for this screen.
Like • 5 people like this
Thomas Schlegel
Great you found the problem. I didn't know that bug.
Olive Sun
HI @Michal Kubiak ,
How did you fix the problem? I meet the same issue and I do find the label in the new issue view layout. It just cannot be edit.
Olive
Michal Kubiak
Have you added this field in the view/edit issue screen configuration?
Olive Sun
Yes, I did.
Olive Sun
Once i changed back to old issue view, it works well.
Michal Kubiak
In the old issue view it will work even if it's not added to the view screen configuration. It worked for me in the new issue view when I updated the screen configuration.
Olive Sun
OK. It seems not work to me. I'll contact the Jira support. Thanks, Michal.
Martin Seehase
February 13, 2020
I got the same issue since yesterday.  Before the "new" layout worked fine with editing labels. Today it does not. Maybe it's a problem with the latest update?
Olive Sun
I think so! For me it also worked well before.
Daniel Gonzalez
February 13, 2020
+1 here!
Andrii Sokorenko
February 13, 2020
just press "L" on your keyboard when you are on the issue and start typing. the UI is broken..
Martin Seehase
February 13, 2020
Using your method, you can access the field, but you can't save new labels or delete existing ones. :-(
Andrii Sokorenko
February 13, 2020
on-going incident with JIRA regarding labeling
https://jira-software.status.atlassian.com/incidents/3xd28t3kf09v
