×I just created a new project (Beta version). I added few columns and then exited.
Now system is not allowing me to add more columns. Can anybody help?
Hello Nupur,
Are you an administrator on that project?
If you have Administer Jira Global Permission, you should be able to grant you Administrator permission in the Agility Project.
After that, you should be able to add more Columns to the board click on the + button in the right corner of Project's Board menu.
Let me know if that helps you.
Francisco Oselame.
Great. This really was useful. Thanks a ton :)
