×I'd like to have some kind of TODO lists in my issues. I see that there are pluggins for server version, but I can't find anything in Markeplace for Cloud.
4 years late for Martiniano but never too late for the world wide web - sure helped me :P
Though four years later, I was looking just for the same option. Thank you Martiniano for your initial question and Geordie for the response.
Hi Martiniano,
JIRA Agile might be a good solution for you.
Please check https://www.atlassian.com/software/jira/agile for further information.
Thanks and regards,
Paula Silveira
Hi Martiniano,
I believe there's an add-on for the cloud that is Any.do for JIRA that might suit your needs.
Hope this helps.
Clarissa.
Thank you Clarissa, but this is not what I'm looking for. I need a list of tasks inside my issues.
