How to auto populate the values ​​of custom fields based on another custom field value selected?
Lender
November 25, 2020 edited
Is there a way to auto populate the values ​​of custom fields based on another custom field value selected?
Remark: Each field has default values and ordered options. "Select List (single choice)"
For example:
 The custom field "Document" has the options:
1
2
3.
 The custom field "Area" has the options:
Marketing
Administration
Financial.
 The custom field "Execution Priority" has the options:
Normal
Critical
Low.
If I select the FIRST VALUE in the "Document" custom field, the other fields should automatically select the FIRST value:
Area: Marketing
Execution Priority: Normal.
If I select the SECOND VALUE in the "Document" custom field, the other fields should automatically select the SECOND value:
Area: Administration
Execution Priority: Critical.
If I select the THIRD VALUE in the "Document" custom field, the other fields should automatically select the THIRD value:
Area: Financial
Execution Priority: Low
Any help is greatly appreciated!
Daniel Ebers
November 28, 2020
Hi Leandro,
there were several approaches in the past how users addresses this requirement:
Automation is pretty popular with Cloud whereas the first two approaches were spread in the wild life across Server instances very often.
When speaking of Apps there might be a plenty more that are capable of catering that need.
Daniel
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
