Hi guys,
I have JSM Cloud and trying to find out how to do the following:
When issue is created and the request type is ..., then assign issue to a certain user.
How can I do it with automations? Or is there better way to achieve this?
Hello @Anastaseeya
You can do this by automation rule:
Just adjust it for your needs and you are good to go.
Yes, thanks for your speedy reply. I know it sounds like an easy to do, but I don't see how to add request type equals step:
No worries! You can click on IF: Add conditon, then select the Issue fields condition. For the field you would choose Request Type (type in the search) and then select your desired request type.
After that as a new component Add an action. Select the Assign user. From there you can leave the Assign the issue to: Specify user. In the section Select a user, you will get the options to select a specific user.
Thanks a bunch! It worked like a charm.
Enjoy the rest of your day!
Excellent! Could you mark this answer as accepted if someone is looking for the answer, they can find it easily? Thanks!
Help us plant more trees
