How to automatically hide modules from the navigation bar
Jonathan Légal July 16, 2024
Hi there,
I would like to automatically hide some of the modules from the navigation bar. The idea is too remove unnacessary components and help my users to adopt the tool.
By default, when a company-managed project is created I have all the following components shown:
I would like to have something like that, by default:
Is it even possible to do it?
Many thanks for your help.
Jo
Hemalatha Balamurugan July 16, 2024
Hi @Jonathan Légal ,
It can be achieved using Scriptrunner plugin.
If you have the plugin available then you can hide the desired modules from the navigation bar.
Navigate to Scriptrunner -> Fragments -> Hide System or Plugin UI Element
Select the web item that needs to be hidden.
Hope this helps.
Jonathan Légal July 18, 2024
Hi @Hemalatha Balamurugan, thank you for your help. I am using n8n as workflow manager / script executer, I prefer to aggregate everything in the same tool for maintenance purpose. Do you know if that is possible if n8n? If not, do you have a documentation link about how the scriptrunner plugin is doing that?
Hemalatha Balamurugan July 19, 2024
Am not sure about the feasibility of this using n8n. Sharing the Scriptrunner documentation for hiding UI elements,
https://docs.adaptavist.com/sr4js/latest/features/fragments/built-in-fragments/hide-ui-element-built-in-script
Thanks & Regards,
Hema
Jonathan Légal July 19, 2024
Hi @Hemalatha Balamurugan ,
Thank you for your help. I will check the documentation.
Best,
Jo
Like • Hemalatha Balamurugan likes this
Learn more
