I am trying to create a filter that will show me items that are in the backlog, but am having difficulty. I hope that someone can help point me in the right direction, and that it is not an issue of JIRA lacking another feature that I need!
My current filter looks like this:
status != Done AND (Sprint not in (openSprints(), futureSprints()) OR Sprint is not EMPTY) ORDER BY createdDate ASC
If I change it to say only
then I get results that are not in the current sprint - exactly what I need. The only problem is that it excludes items that have previously been assigned to a sprint, but were never completed. If I change it to say only
Sprint is not EMPTY
then I get results that have been previously assigned to a sprint - again, exactly what I need! The only problem is that it excludes items that have never been assigned to a sprint.
When I try to combine the two inside of a parenthesis grouping, I get most of what I need - but for some reason, it is including the items that are in my current (active) sprint.
I feel like this would all be solved by having Atlassian implement a simple "currentSprint()" operator, so that I could say
Sprint not in currentSprint()
Can anyone help me out - or am I out of luck?
What about the JQL below ?
status != Done AND (sprint is EMPTY OR (sprint in (closedSprints())))
Should return all issues
Hi Boris, thanks for responding! This definitely gets me much closer to where I need to be. There are a few items that I'd still like to get rid of though; I see issues carried over from our last sprint (closed) that have been assigned to the current sprint. I really appreciate you taking the time to reply!
So you want to exclude the items from the current sprint right ?
what about this query:
status != Done AND ((sprint is EMPTY OR (sprint in (closedSprints()))) AND (sprint NOT IN (openSprints())))
Yes. Essentially, I want to...
Include:
Exclude:
It seems like the query above is filtering out items that have never been assigned to a previous sprint (i.e. sprint is EMPTY), but I actually need them to be included!
Thanks again for taking the time to respond!
Here's a query similar to the one above with some explanation:
sprint IS EMPTY OR sprint IN closedSprints() AND sprint NOT IN (openSprints(), futureSprints()) AND status != Done
I've corrected my comment above - please try without all the brackets.
This is absolutely what I needed! I owe you a coca-cola! Thanks very much for your patience, and also for taking the time to explain it to me in crayon.
Much obliged!
This definitely helps me as well !! Thank you..
Bumping to see if anyone else has another suggestion. I would be surprised if I were the only one who needs a filter like this. I want to be able to setup a monthly subscription that emails folks with items in the backlog. Am I missing something obvious?
I'm in the same boat. It's absurd that I can't see what's in my backlog at a glance. Right now I'm using this:
project = NAME and sprint IS EMPTY and status = open OR project = NAME and sprint IN closedSprints() AND sprint NOT IN (openSprints(), futureSprints()) AND status = Open
Hey @Adam Tiner
I ran into this same issue and its been a while since you asked this question. I am posting this answer in case anyone else runs into this.
In order to target issues that are in your backlog but not within a future sprint, open sprint, or that was in a closed sprint but was unresolved use this query
Sprint in futureSprints() or Sprint is EMPTY or (Sprint in closedSprints() AND resolution = Unresolved and Sprint not in openSprints())
Now you will need to make sure to filter out all issues that do not have a status of Done or are unresolved
status != Done
or
So the full query would look like this
Sprint in futureSprints() or Sprint is EMPTY or (Sprint in closedSprints() AND resolution = Unresolved and Sprint not in openSprints()) and issuetype in (your issue types here) and resolution = Unresolved
I hope there is an easier way of doing this but the only solution I could come up with. I hope this helps someone.
to me this works nicely project = NAME and (sprint not in openSprints() or sprint is empty)
Help us plant more trees
