How to calculate number of days an issue spent in previous transition status before it reaches to a
Neha Panchal August 17, 2022
Hi Guys,
I am a newbie on eazyBI, and would really appreciate your support on the following query:
I am using Kanban board - JIRA software
I have four columns on the board: Readiness check, In-progress, In-validation, Execution, Done
Two teams work on a single board.
My team only works in the first two columns of the board- Readiness check and In-progress
 So, for us when we move the project to - In-validation status it is completed by our end.
I want to get a report on the number of issues transitioned to - In-Validation (Delivered by my team) in a month and the average number of workdays those issues spent in the previous status - Readiness check & In-progress, to measure my team's execution time.
If you have any other solution by which I can get the execution time of my team, please share that with me.
Thank you!
Emre Toptancı _OBSS_
August 18, 2022 edited
Hello @Neha Panchal ,
Our team at OBSS built Timepiece - Time in Status for Jira for this exact need. You can use Time in Status to get these reports in Jira or use the app's REST API to pull the calculated values to a BI platform.
Time in Status mainly allows you to see how much time each issue spent on each status and on each assignee
tisCloud_StatusDuration_LeadTime_with Estimates.png   tisCloud_AssigneeDuration.png
The app has Consolidated Columns feature. This feature allows you to combine the duration for multiple statuses into a single column and exclude unwanted ones. It is the most flexible way to get any measurement you might want. Measurements like Issue Age, Cycle Time, Lead Time, Resolution Time etc.
For all numeric report types, you can calculate averages and sums of those durations grouped by the issue fields you select. For example total in-progress time per customer (organization) or average resolution time per sprint, week, month, issuetype, request type, etc. The ability to group by parts of dates (year, month, week, day, hour) or sprints is particularly useful here since it allows you to compare different time periods or see the trend.
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well. It supports both Company Managed and Team Managed projects.
Time in Status reports can be accessed through its own reporting page, dashboard gadgets, and issue view screen tabs. All these options can provide both calculated data tables and charts.
And the app has a REST API so you can get the reports from Jira UI or via REST.
Gadget_AverageStatusDurationByComponent.png   tisCloud_StatusDuration_LeadTime_Chart.png
Using Time in Status you can:
  • See how much time each issue spent on each status, assignee, user group and also see dates of status transitions.
  • Calculate averages and sums of those durations grouped by issue fields you select. (For example, see average InProgress time per project and per issue type.)
  • Export your data as XLS, XLSX, or CSV.
  • Access data via REST API. (for integrations)
  • Visualize data with various chart types.
  • See Time in Status reports on Jira Dashboard gadgets
EmreT
Martins Vanags_eazyBI
Hi @Neha Panchal
Welcome to the eazyBI world.
You might want to check the predefined measures "Transitions to status issues count" and "Average workdays in transition status" that would let you calculate the count of issues that moved to a displayed status and also the average time in workdays issue spent in the transition before it was changed
Just use the "Transition status" dimension instead of the "Status" dimension in report columns.
Then add the "Time" dimension to page filters and select the time period for your report.
See a similar report here: https://eazybi.com/accounts/1000/cubes/Issues/reports/145950-average-time-in-status-cycle-time
Martins / support@eazybi.com
Hi @Martins Vanags_eazyBI ,
Thank you for your quick reply.
Actually, with these measure combinations, I am getting no. of issues transitioned to different statuses & the number of days spent in transition status for a particular selected month/period.
But I am more interested in finding:
For a particular month, the number of issues that transitioned to a particular status (from In-progress or Readiness check to "In-Validation") in a month, and for those found issues - the average number of days when they were in the previous status (In-progress or Readiness check ).
Is it possible to get this data?
@Neha Panchal
It sounds possible. You could try creating new user-defined measures to combine transition dimension members and then do some issue-level calculations for the first set of issues to find the average number of workdays issues spent in both statuses previous for a given month. For more details please reach out to support@eazybi.com and share more details about the layout of your report.
Martins / eazyBI
Lakshmi Priya August 17, 2022 edited
@Neha Panchal Did you try checking this plugin if it helps ?
Time in Status Reports
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
