How to call multiple remote backends from a single module, without using the forge backend
Pratiksha Kate August 5, 2024
I am new to Forge and need to request different baseURLs from my Forge front end.
Currently, Forge doesn’t support configuring multiple remotes within a single module.
While I can set up several remotes with different keys in the manifest, each pointing to a different base URL, and create multiple endpoints for these remotes, I am limited to using only one endpoint as a resolver in the module.
Is there a way to request multiple base URLs from the Forge frontend using invokeRemote or any other way?
Best regards,
Pratiksha Kate
Register now
