I know we can set automation rules that will work on the issues that are getting updated after making the automation live for them, is there any way we can run the automation rule for existing issues?
In particular, I need to capture the date of a workflow transition for Defects created on a board from Jan'24 to Mar'24
Hi @Shubham R
That information is in the issue history, but it is difficult to access using automation rules. This is one reason marketplace addons often help with this need.
It may be possible to get that date using an automation rule, but first let's check the extent of this need:
Assuming there are several issues, and they have not had too many updates, a rule could be built as follows:
This rule could be allow to run until all of the values are captured, and then the rule could be disabled.
Hi @Shubham R !
I would recommend using the "Scheduled" trigger to immediately run the automation on all of your existing issues. After the automation has been run, you should change the trigger to be what would work best for your use case (maybe keep it as Scheduled but make it less frequent, change the trigger to be when the issue transitions to a specific state, and so on).
I hope this helps!
