How to change a story to a subtask?
Kirsi Tamminen February 13, 2024
I have created a story and now I realize that it should be a subtask instead under different story. Can I change the status? Is it possible other way around?
BR,
Kirsi
3 votes
Rilwan Ahmed
Hi @Kirsi Tamminen ,
  1. If your story has sub-tasks, move them to appropriate parent ticket or create a parent ticket and then move them.
  2. Now convert your story to a sub-task. i.e. Open ticket --> click on Issue type Icon --> select our sub-task ticket type.
  3. In the next screen, give the correct parent ticket number under which you need this ticket to be moved
I see, that was simple, thank you!
BR, Kirsi
Like • Rilwan Ahmed likes this
Kiran Rao
April 18, 2024 edited
I am unable to see Sub Task in the dropdown. How do I fix that
Like • 4 people like this
Mike Halleen
May 14, 2024
I also want to do this but don't see "sub task" in the list of types I can change it to.
Like • 2 people like this
ACN Helpdesk
I can't see it either.
