How to change assignee on create issue?
Pranita Warik January 30, 2023
I am using the Intenso Plugins for changing the assignee on the create issue post function. We have upgraded to 9.4 version of jira, which does not support the Intenso Plugin. Let us know if there is any other plugin which can help to solve this.
Amed Moreno January 30, 2023 edited
Hi Pranita,
Is the assignee field associated to the project "create issue" screen for the particular issue type you're trying to create?
Usually, you can add the assignee field to the "create issue" screen and when clicking create (to create a jira issue), you will see the field there which can be edited before the issue is created.
I hope this helps.  :)
Kind Regards,
Amed
SERVER
VERSION
9.4
