How to change date format to Brazil format?
Vitor Lima October 8, 2019
The language of jira is set to Portuguese Brazil, the format also shows dd / mm / yyyy, but when I create a date field it does not come in the format of Brazil but in the USA format, including the text in the calendar. How do I resolve this to bring the format right to my language?
Angélica Luz
October 9, 2019 edited
Hi Vitor,
It looks like you're running into an existing bug, which can be found here:
I tested here and indeed, on the new issue view, even changing my profile language and the system language to Portuguese, the calendar on the new issue view shows in English, but on the old view, it shows in Portuguese.
Old view:
Please be sure to watch it, so that you are notified when this is fixed in a future release.
Angélica
Vitor Lima October 9, 2019
@Angélica Luz
Thanks so much for the response, how soon should this bug be fixed?
Angélica Luz
October 11, 2019
The bug is on our backlog, but we still don’t know when it will be fixed.
Feel free to add a comment on the bug for our dev team to check.
You can find more details about our Bug Fix Policy on the link below:
