I had added around 600+ test cases in Test Repository and I have pulled X number of test cases to Test Executions. My doubt is How to check if a test case is pulled in for test execution or not in jira? I understand that I can check this, test case by test case but How can i find this in bulk ?
Hi @Sukanya ,
Can you maybe share more details on which Marketplace app you are using for this? Is it Zephyr, Xray, or something else?
You can also reach out to vendors directly by using one of their support channels, which should be visible on each Marketplace app listing (open app listing > select "Support" tab).
Tobi
