How to check the value of a checkbox field in a groovy expression on post function?
V788 April 7, 2017
I want to use the post function that set the value of of a field based on a groovy expression. In this expression I need to check if a specific value was checked in a custom checkbox field.
Sam Hall
April 7, 2017 edited
Hi Maria - This isn't standard functionality, so I'm guessing you might be using a post function provided by the JIRA Misc Workflow Extensions add-on. Am I correct?
Which version of JIRA are you using? Cloud or Server?
If you can provide this info, it should help get an answer for your question.
Sam Hall
April 7, 2017
Register now
