How to clear Fix Version/s field
Paolo Botti July 17, 2018
I have to clear field named "Fix Version/s" but I cant find in edit screen than I try with bulk modify but there are no way to do that.
Any help ?
Mikael Sandberg
Make sure the field is on the edit screens for all the issue types you are trying to bulk edit. If the field is missing on the screen for one of the types, it will not be available during bulk edit.
Paolo Botti July 18, 2018
Thank you Mikael, I clear "Affects Version" not "Fix Version".
Now I clear both and issue it's fixed.
But "Fix Version" is only visible, if I edit issue then filed is not available.
Thks
Kristian Walker _Adaptavist_
Hi Paolo,
If you have the Adaptavist ScriptRunner for Jira Cloud plugin installed then you can clear the fix version and affects version field for an issue using the example script located here which can be ran from the Script Console.
Please note that for this script to work both the Affects Version and Fields version must be on the edit screen for the issue.
If this answer has solved your issue can you please accept it in order to mark this answer as correct for users who are searching for a similar issue.
Kristian
danna deaton
Is there a way to do that as a post-function?  I need to clear the Fix Version/s when an issue is reopened.
Like • 3 people like this
