How to clear a system field eg: in log work date started
Mohanbabu Somasundaram December 25, 2019
Need to clear date started field. if user click on log work the system field date started should be cleared.
Nic Brough -Adaptavist-
December 26, 2019
You will need an automation or scripting app to provide a listener function that can spot the log-work event and clear out your custom "date started" field (it's not a system field, Jira doesn't have a date started field built in)
Mohanbabu Somasundaram December 27, 2019
Hi Nic
Thanks for your update, do you able to provide me a sample script for this scenario, I have script runner addon to implement this.
December 27, 2019
https://library.adaptavist.com/entity/change-the-value-of-a-custom-field-in-a-post-function is a good start.  It sets a text field to some text, but you can just set your "date started" to null to blank it out.
Mohanbabu Somasundaram December 30, 2019
Thank you Nic i will check this script and update you if there is an issue.
