I have created a custom field that is a select-list-cascading field in my project.
I have also created an automation in which I want to empty the values in this field that are present in an issue that is being updated.
I am not a programmer and have been trying to search around for a solution but I am not getting very far.
Basically the field at the parent level is "Co. Name" with a child value of "Discount".
I want to clear this custom field in the current issue that the automation rule is updating.
Can someone help me with the coding necessary in the advance field editing to accomplish this please?
Suzanne
For a question like this, please post an image of your complete automation rule, images of any relevant actions / conditions / branches, an image of the audit log details showing the rule execution, and explain what is not working as expected. Those will provide context for the community to offer ideas. Thanks!
Until we see those...
In automation rules, cascading fields are updated using the advanced edit with JSON, as described here: https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/#Cascading-select-custom-field
For example, if you want to clear the parent and child levels for a field, the JSON could be this:
"fields": {
"customfield_12345": { "value" : null }
Where customfield_12345 is the custom field id for your field. Please let me know if you want help finding that value.
Hi Bill,
Thanks for your answer. I tried your suggestion but I got an error.
Here is the simple rule.
Basically when one field is updated (the trigger) I want to delete any content out of another custom field (customfield_10123) in the same issue.
The value in the custom field could be different per issue.
Does this help explain what I am trying to achieve?
Thanks.
That is odd, if you are using one of the built-in cascade select lists. Would you please confirm the following:
Next, smart values are name, spacing, and case sensitive. So try changing "Value" to "value".
If that does not work, I recommend following what the error states: change "value" to either "id" or "name".
Wow! The capital V was in deed the problem... I changed to "value" and it works correctly!
Thanks so much for your help.
HI @Suzanne Cranfield - Have you tried manually clearing each sub-levels ?
Hi Humashankar. Yes I can delete manually but I want to automate it for the Users.
Save your spot
