How to clone a full Prod instance to a new Test instance
serge calderara
January 5, 2021
Dear all,
We have actually a customer running a single Prod Jira instance with different type of configuration, plugins and settings....
We need to setup based on that PROD instance a TEST instance which is an exact copy of the PROD.
By using the Site Export/Import method, does this takes 100% of everything in order to get the TEST instance fully matching PROD or do we need to perform some preliminary installation on TEST instance before importing Prod data ? like installing plugins or does plugins gets install automatically when site import process is run ?
Thanks for sharing your experience
regards
Kian Stack Mumo Systems
@serge calderara, post restore you'll want to reinstall all of the apps! The only other thing you might need to take a look at is your user management/product access and make sure those are set up how you want.
serge calderara
January 6, 2021
Hello @Kian Stack Mumo Systems what do you mean by :
"management/product access"
Do you mean that before restoring the site we need to configure all user account in the TEST instance ?
regards
@serge calderara, no.  When you restore one site to another it automatically disables access for basically everyone but site-admins. You'll need to set up access if you want other people to have access to the site.
Kian
serge calderara
January 6, 2021
Dear @Kian Stack Mumo Systems , so if I undertsand well the steps are as below :
1- Create the test Instance
2 - Add all same plugins which are in Prod instance
3- Perform site restore on test instance
4 - Give access to application
Is that flow correct ?
If I understand well user account will be automatically created from prod backup into Test instance correct as well ?
@serge calderara
I'd flip steps 2/3, but otherwise it sounds correct. I'd also double check your default product access settings to make sure that new users don't get all products when they are created prior to performing the restore.
serge calderara
January 6, 2021 edited
I do not undertsand what you mean by checking default access because the PROD instance is already up and running LIVE and correct user have accesss as it should
So if I made a backup of PRODuction site and restore on new Test instance, all users rights should be correctly set no ?
Restore site should be done before installing plugins ?
It will not generate errors by doing so ?
No, it shouldn't.
Edit: No, it shouldn't generate any errors.
Man Tsang June 17, 2022 edited
I'm in a similar situation, but I encounter a 500 error that I can't even access JIRA with my admin account. JIRA keep showing me the 500 error page no matter what account I tried to use to login.
So I installed a new instance of JIRA, created an admin user and a local non-admin user account. Then I imported one of the backup files from production instance into this test instance. After the import was done, I lost my admin access as well as the local non-admin user access. I tried to use my admin account from Prod instance to login, but I just keep getting the 500 error page.
I hope you can help.
It produced some java exception stack trace here for the test instance:
com.atlassian.crowd.exception.runtime.UserNotFoundException: User <admin_account> does not exist
 at com.atlassian.crowd.embedded.core.CrowdServiceImpl.setUserAttribute(CrowdServiceImpl.java:338) [embedded-crowd-core-2.10.4.jar:?]
 at com.atlassian.crowd.embedded.core.CrowdServiceImpl.setUserAttribute(CrowdServiceImpl.java:324) [embedded-crowd-core-2.10.4.jar:?]
 at com.atlassian.jira.security.login.LoginStoreImpl.setLong(LoginStoreImpl.java:132) [classes/:?]
 at com.atlassian.jira.security.login.LoginStoreImpl.updateLastFailedLoginTime(LoginStoreImpl.java:121) [classes/:?]
 at com.atlassian.jira.security.login.LoginStoreImpl.recordLoginAttempt(LoginStoreImpl.java:51) [classes/:?]
 at com.atlassian.jira.security.login.RecoveryLoginStore.recordLoginAttempt(RecoveryLoginStore.java:60) [classes/:?]
 at com.atlassian.jira.security.login.LoginManagerImpl.recordLoginAttempt(LoginManagerImpl.java:320) [classes/:?]
 at com.atlassian.jira.security.login.LoginManagerImpl.onLoginAttempt(LoginManagerImpl.java:216) [classes/:?]
 at com.atlassian.jira.security.login.JiraElevatedSecurityGuard.onFailedLoginAttempt(JiraElevatedSecurityGuard.java:26) [classes/:?]
 at com.atlassian.seraph.filter.PasswordBasedLoginFilter.runAuthentication(PasswordBasedLoginFilter.java:147) [atlassian-seraph-3.0.3.jar:?]
 at com.atlassian.seraph.filter.PasswordBasedLoginFilter.login(PasswordBasedLoginFilter.java:78) [atlassian-seraph-3.0.3.jar:?]
 at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:110) [atlassian-seraph-3.0.3.jar:?]
 at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:77) [classes/:?]
 at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) [atlassian-core-5.0.9.jar:?]
 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) [catalina.jar:8.5.32]
 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) [catalina.jar:8.5.32]
 at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:39) [atlassian-plugins-servlet-4.5.1.jar:?]
 at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:58) [atlassian-plugins-servlet-4.5.1.jar:?]
 at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:67) [?:?]
 at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:64) [atlassian-plugins-servlet-4.5.1.jar:?]
 at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:37) [atlassian-plugins-servlet-4.5.1.jar:?]
 at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:56) [?:?]
 at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:70) [atlassian-plugins-servlet-4.5.1.jar:?]
 at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:58) [atlassian-plugins-servlet-4.5.1.jar:?]
 at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99) [atlassian-profiling-1.9.jar:?]
 at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:16) [classes/:?]
 at com.atlassian.jira.web.filters.johnson.JiraJohnson503Filter.doFilter(JiraJohnson503Filter.java:79) [classes/:?]
 at com.atlassian.jira.web.filters.johnson.JiraJohnsonFilter.doFilter(JiraJohnsonFilter.java:72) [classes/:?]
 at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176) [urlrewritefilter-4.0.3.jar:4.0.3]
 at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145) [urlrewritefilter-4.0.3.jar:4.0.3]
 at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) [urlrewritefilter-4.0.3.jar:4.0.3]
 at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394) [urlrewritefilter-4.0.3.jar:4.0.3]
 at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30) [classes/:?]
 at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:42) [?:?]
 at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:39) [?:?]
 at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21) [?:?]
 at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36) [?:?]
 at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74) [classes/:?]
 at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:31) [atlassian-core-5.0.9.jar:?]
 at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:39) [atlassian-core-5.0.9.jar:?]
 at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:41) [classes/:?]
 at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:36) [classes/:?]
 at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25) [classes/:?]
 at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:57) [classes/:?]
 at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:115) [atlassian-gzipfilter-3.0.0.jar:?]
 at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:92) [atlassian-gzipfilter-3.0.0.jar:?]
 at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198) [catalina.jar:8.5.32]
 at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) [catalina.jar:8.5.32]
 at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:493) [catalina.jar:8.5.32]
 at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140) [catalina.jar:8.5.32]
 at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81) [catalina.jar:8.5.32]
 at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87) [catalina.jar:8.5.32]
 at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:650) [catalina.jar:8.5.32]
 at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342) [catalina.jar:8.5.32]
 at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:800) [tomcat-coyote.jar:8.5.32]
 at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) [tomcat-coyote.jar:8.5.32]
 at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:800) [tomcat-coyote.jar:8.5.32]
 at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1471) [tomcat-coyote.jar:8.5.32]
 at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) [tomcat-coyote.jar:8.5.32]
 at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:1.8.0_333]
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:1.8.0_333]
 at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) [tomcat-util.jar:8.5.32]
 at java.lang.Thread.run(Unknown Source) [?:1.8.0_333
I'm in a similar situation but after importing the backup data from prod instance to this test JIRA instance, I just cannot login and keep getting this 500 error page.
So I installed a new instance of JIRA, created an admin account and a non-admin local user account. Then I imported one of the backup data files from prod instance into this test instance. After the import was completed I couldn't login with either my admin account or the non-admin account. I also tried to login with one of the admin account from prod instance but I still failed and only get that 500 error page.
Here are some java exception stack trace output:
 at java.lang.Thread.run(Unknown Source) [?:1.8.0_333]
I'm in a similar situation, but after importing one of the backup data file from production instance into this test instance, I'm not able to login. I tried to use the admin account from production instance, still failed. I just keep getting the 500 error page.
Here's some of the java exception stack trace output:
