How to clone an issue to a specific version of project using Automation rule?
Thanks for your reply
I want to clone one issue which is already created to other version of a project ,is this is possible with automation
Mallikarjuna V
Yes, we can create it.
You can select any trigger conditions based on your use case, such as issue updated, transitioned, or scheduled.
Next, in the conditions, add JQL or field conditions, and then include an "Edit Issue" action to clone the issue into a particular project.
Great! Thanks for the update.
Could you please accept my answer
Hi @Mallikarjuna ,
You can do this using the issue created or transitioned trigger and a condition to check that the fixed versions. Your rule would look like this:
Hope that helps!
Geethanjali
