How to config SSL certificate for Jira and Confluence by HAProxy?
Raw Main
February 28, 2020 edited
Using HAProxy version: 2.1.3
I did setting in the /etc/haproxy/haproxy.cfg file:
frontend jira
# bind :::8080 v4v6
bind :::443 v4v6 ssl crt /home/user/ssl/server.pem
http-request redirect scheme https unless { ssl_fc }
default_backend jira
frontend confluence
# bind :::8090 v4v6
default_backend confluence
backend jira
balance roundrobin
cookie JIRASESSIONID prefix nocache
http-request add-header X-Forwarded-Proto https if { ssl_fc }
server jira1 [IPv6 IP]:8080 check cookie jira1
server jira2 [IPv6 IP]:8080 check cookie jira2
backend confluence
balance roundrobin
cookie CONFSESSIONID prefix nocache
server confluence1 [IPv6 IP]:8090 check cookie confluence1
server confluence2 [IPv6 IP]:8090 check cookie confluence2
Before I add 443 setting, 8080 and 8090 bind worked well.
But in this case, when restart haproxy, got this error:
Job for haproxy.service failed because the control process exited with error code. See "systemctl status haproxy.service" and "journalctl -xe" for details.
When use journalctl -xe to see detail, got:
Feb 28 17:44:21 server systemd[1]: haproxy.service: control process exited, code=exited status=1
Feb 28 17:44:21 server haproxy[30436]: Errors found in configuration file, check it with 'haproxy check'.
Feb 28 17:44:21 server systemd[1]: Failed to start SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high
-- Subject: Unit haproxy.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit haproxy.service has failed.
-- The result is failed.
Feb 28 17:44:21 server systemd[1]: Unit haproxy.service entered failed state.
Feb 28 17:44:21 server sudo[30429]: pam_unix(sudo:session): session closed for user root
Feb 28 17:44:21 server systemd[1]: haproxy.service failed.
Feb 28 17:44:21 server polkitd[2570]: Unregistered Authentication Agent for unix-process:30430:138824114 (system bus name :1.76278,
Why it failed to start SYSV?
Now using IPv6, how to config it correctly?
I did Jira(8.6.1) configuration setting for <JIRA_INSTALL>/conf/server.xml:
Comment out:
<Connector port="8080" relaxedPathChars="[]|" relaxedQueryChars="[]|{}^&#x5c;&#x60;&quot;&lt;&gt;"
maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false"/>
Uncomment:
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" secure="true" scheme="https"
proxyName="<subdomain>.<domain>.com" proxyPort="443"/>
Maybe it will work if set real proxyName.
Alexis Robert
Hi @Raw Main ,
I think you have an error because you're trying to bind port 443 for two different backends : HA Proxy can't know when it should send the requests to Jira or Confluence.
You should use the following condition in your frontend block for Confluence for example:
 acl url_confluence path_beg /confluence
use_backend confluence if url_confluence
 and then do the same for Jira. You should then configure Jira and Confluence to use context path to add /jira or /confluence at the end of the URL, as described here : https://confluence.atlassian.com/jirakb/change-the-context-path-used-to-access-jira-server-225119408.html
You can have a look at this page where a solution is given at the end for Jira and Confluence using HA Proxy : https://discourse.haproxy.org/t/multiple-backend/4490/6
Let me know if this helps,
--Alexis
Raw Main
@Alexis Robert
Hi Alexis,
Thank you very much for your reply. It's very helpful.
One thing, I have to use subdomain as:
frontend jira.mysite.com
frontend confluence.mysite.com
 It's not
mysite.com/jira
mysite.com/confluence
How to config it in this case?
Alexis Robert
Hi @Raw Main ,
you will have to use the following syntax to route based on your subdomain :
# Define hosts
acl host_jira hdr(host) -i jira.mysite.com
acl host_confluence hdr(host) -i confluence.mlysite.com
## figure out which one to use
use_backend jira_backend
if host_jira
use_backend confluence_backend
if host_confluence
--Alexis
Raw Main
Hi @Alexis Robert ,
I think you mean:
frontend http_https
bind *:443 ssl crt /home/user/ssl/server.pem
acl host_confluence hdr(host) -I. confluence.mlysite.com
use_backend jira if host_jira
use_backend confluence if host_confluence
backend jira
balance roundrobin
backend confluence
balance roundrobin
 But after I restart haproxy:
$ sudo systemctl restart haproxy
Again got error as:
When check details use "journalctl -xe" , got:
Mar 01 14:02:41 server systemd[1]: Unit haproxy.service entered failed state.
Mar 01 14:02:41 server systemd[1]: haproxy.service failed.
Mar 01 14:02:41 server polkitd[2570]: Unregistered Authentication Agent for unix-process:5802:154774153 (system bus name :1.85445,
Mar 01 14:02:41 server sudo[5801]: pam_unix(sudo:session): session closed for user root
Mar 01 14:02:48 server sudo[5822]: user : TTY=pts/0 ; PWD=/home/user/haproxy-2.1.3 ; USER=root ; COMMAND=/bin/vi /etc/h
Mar 01 14:02:48 server sudo[5822]: pam_unix(sudo:session): session opened for user root by user(uid=0)
Mar 01 14:02:56 server sudo[5822]: pam_unix(sudo:session): session closed for user root
Mar 01 14:02:58 server sudo[5831]: user : TTY=pts/0 ; PWD=/home/user/haproxy-2.1.3 ; USER=root ; COMMAND=/bin/systemctl
Mar 01 14:02:58 server sudo[5831]: pam_unix(sudo:session): session opened for user root by user(uid=0)
Mar 01 14:02:58 server polkitd[2570]: Registered Authentication Agent for unix-process:5833:154775818 (system bus name :1.85448 [/u
Mar 01 14:02:58 server systemd[1]: Starting SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availa
-- Subject: Unit haproxy.service has begun start-up
-- Unit haproxy.service has begun starting up.
Mar 01 14:02:58 server haproxy[5839]: Enter PEM pass phrase:
Mar 01 14:02:58 server haproxy[5839]: [ALERT] 060/140258 (5843) : parsing [/etc/haproxy/haproxy.cfg:64] : 'bind *:443' : unable to
Mar 01 14:02:58 server haproxy[5839]: [ALERT] 060/140258 (5843) : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
Mar 01 14:02:58 server haproxy[5839]: [ALERT] 060/140258 (5843) : Fatal errors found in configuration.
Mar 01 14:02:58 server haproxy[5839]: Errors found in configuration file, check it with 'haproxy check'.
Mar 01 14:02:58 server systemd[1]: haproxy.service: control process exited, code=exited status=1
Mar 01 14:02:58 server systemd[1]: Failed to start SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high
Mar 01 14:02:58 server systemd[1]: Unit haproxy.service entered failed state.
Mar 01 14:02:58 server systemd[1]: haproxy.service failed.
Mar 01 14:02:58 server sudo[5831]: pam_unix(sudo:session): session closed for user root
Mar 01 14:02:58 server polkitd[2570]: Unregistered Authentication Agent for unix-process:5833:154775818 (system bus name :1.85448,
It shown:
Usually it because of install HAProxy without OpenSSH. So I tried to reinstall haproxy by source:
make TARGET=linux-glibc USE_OPENSSL=1 USE_PCRE=1 USE_ZLIB=1
sudo make install
Then I can find OpenSSL there:
$ haproxy -vv | grep OpenSSL
Built with OpenSSL version : OpenSSL 1.0.2k-fips 26 Jan 2017
Running on OpenSSL version : OpenSSL 1.0.2k-fips 26 Jan 2017
OpenSSL library supports TLS extensions : yes
OpenSSL library supports SNI : yes
OpenSSL library supports : SSLv3 TLSv1.0 TLSv1.1 TLSv1.2
I run this check details follow https://discourse.haproxy.org/t/haproxy-not-starting-with-ssl-configuration/2330 :
haproxy -c -f haproxy.cfg
It let me input phrase:
I only have a .csr file and a .pem file(Maybe they aren't created by OpenSSL). I don't know the phrase.
How to use it correctly?
Adam Hagen
February 22, 2024
If anyone runs across this post in the future I wanted to add the probable fix. I'd wager that selinux was blocking haproxy from binding to 443. I only post this because the changes Alexis pointed out and made to the haproxy.cfg definitely would've stopped haproxy from starting as well.
If your config checks out with 'haproxy -c -f /etc/haproxy/haproxy.cfg' but the service fails to start on a system with selinux, it's selinux.
Dave Harding
June 9, 2025
I think that the reason that @Raw Main had a second issue was a copy/paste error with the acl (probably), along with a typo by @Alexis Robert where he put an "l" in to mysite for Confluence (ie. mlysite). The acl is incorrect:
see the extra "l"; it should be:
acl host_confluence hdr(host) -i confluence.mysite.com
