How to configure SSL for eazyBI for Jira Postgres connection
Christopher St_ John August 30, 2023
I am running Jira v9.4.7 and eazyBI Reports and Charts for Jira v6.6.0. I cannot find any information on how to setup SSL for Postgres in eazyBI. When I configure eazyBI settings I can check the box "Use SSL" which fails because  also need to specify the location of the certificates. How can I specify the jdbc url with:
ssl=true
sslmode=verify-full
sslrootcert=/my/rootcert
sslkey=/my/key.pk8
sslcert=/my/sslcert
Christopher St_ John September 6, 2023
I was able to get it working by adding the following to eazybi.toml and restarting Jira. I had an existing non-ssl database connection.
[database.advanced.properties]
sslcert= "/path/to/public.crt"
sslkey = "/path/to/private.key"
sslmode = "verify-full"
sslrootcert = "/path/to/ca-chain.cer"
I also found out I could add the following to the installer advanced settings and it would work too. I did not check the box "Use SSL" in the eazyBI settings because sslmode was specified. I'm guessing if I checked the box I did not need to specify sslmode.
[properties]
Gerda Grantiņa
August 31, 2023
Hi @Christopher St_ John
On eazyBI, you can enable SSL for PostgreSQL with those Database advanced settings:
[properties]
sslmode = "require"
For more information, check this documentation about eazyBI installation on PostgreSQL: https://docs.eazybi.com/eazybi/set-up-and-administer/atlassian-server-and-data-center/installation-on-jira#InstallationonJira-PostgreSQL
Best,
Gerda // support@eazybi.com
Marc - Devoteam
August 30, 2023
I think your question relates to SSL setup for EazyBI this can be found in their documentation
https://docs.eazybi.com/eazybi/set-up-and-administer/private-eazybi/https-or-ssl-setup
Thanks for the reply, but the document is for eazyBI's web page. I need the SSL setup for the Postgres database connection.
Like Marc - Devoteam likes this
Marc - Devoteam
August 30, 2023
I would reach out to eazyBI directly for help on the configuration. They should have had this question before.
I would ask them if they are able to update their documentation on the topic as well if its not in there or not in a logic location
