How to configure fields for Epic on certain projects
Jade Melcher
How would I edit the fields that show for the Epic issue type on specific projects? I do not want to edit the epic issue type layout for ALL projects, only a subset.
Alexey Matveev
January 2, 2019
Do you want to edit screens for the Epic issue type for some projects? If so, then copy current issue type screen scheme scheme, associate the copied issue type screen scheme to the required project and then change the screens in this issue type screen for the Epic issue type.
You can find more info about issue type screen schemes here:
https://confluence.atlassian.com/adminjiraserver/associating-screen-and-issue-operation-mappings-with-an-issue-type-938847305.html
Jade Melcher
Thank you so much! I finally learned how and your instructions helped a ton!
