How to convert dashboard with tickets into structure?
Ясена Иванова
October 6, 2025
I would like to convert dashboard with tickets into Jira structure. Under every ticket I want to obtain better visualisation with the linked tickets of other teams. Also I would like to have timeline with the expected end date of the closure of the tickets, and also time of every update of the ticket.
Rahul_RVS
Hi @Ясена Иванова
Welcome to the community !!
Not sure if this can be achieved out of the box in Jira. If you are open to try out a mktplace solution for this need, I can suggest
Issue Hierarchy
The app allows you to view your project issue links (cross projects as well) in a tree view. You can also view %complete progress at each parent level. It sums up the time tracking fields, story point or numeric fields at each parent level, along with a timeline view. The app can be added to a dashboard as well.
Disclaimer : I am one of the app team member
Ясена Иванова
October 6, 2025
Thank you very much, Rahul. I am appreciated. I will try with the app.
Like Rahul_RVS likes this
Mariia_Domska_SaaSJet
Hello @Ясена ИвановаWelcome to the community!
If you’re open to trying an app for your request, I’d recommend checking out No-code Apps Creator for Jira, developed by my team.
It lets you build custom visualizations and interactive dashboards right inside Jira — no coding required, just through simple chat with AI. It works like GPT chat inside Jira :)
You can easily:
  • Display linked tickets across multiple teams in a clear structure
  • Add timelines for progress and expected end dates
  • Show update times and other key fields dynamically
It’s built on Forge, so everything stays secure and admin-controlled within the Atlassian Cloud.
I’d really appreciate it if you could give it a try and share your thoughts https://saasjet.com/5ros
Joshua Brock _ Seibert Group_ GmbH
Hello @Ясена Иванова !
Just another option as we have a fully integrated plugin for Jira, for roadmapping, dependency management, and reporting. I invite you to look at either our Cloud or DC version of Agile Hive.
Best of luck and certainly if down the road you're looking for a integrated and extended solution, please reach out!
Joshua
Content & Technical Writer
Agile Hive
