How to convert defect to sub-defect?
Nadiia Stasyk
August 25, 2023
As a QA I would like to be able to convert a work item type from defect to subdefect. How could I do it?
Jehan Bhathena
Nadiia Stasyk
August 25, 2023
Thanks. The option to convert the item to sub-defect by clicking on the work item icon does not give me Sub-defect as an available option for selection. It seems to be the most intuitive option.
But I could do it by clicking on the three dots on the right upper corner of the defect, select Convert to Sub-Task option, and then change it to Sub-Defect
Like Jehan Bhathena likes this
Jehan Bhathena
Hi @Nadiia Stasyk
Glad to know it works for you.
If this thread helped please can you mark it as the Accepted Answer.
Like Nadiia Stasyk likes this
