Hi Everyone,
We have one custom field called select list single Choice.
We need to convert that field to text field.
Can anyone help me to do that.
Geethanjali.
You cannot convert an existing drop down field to a text field, but hope is not lost. @Mayur Ramesh Jadhav provided these excellent steps to solve your issue in this thread.
Migrating Custom Field content to another field using CSV import:
4. Open in an Excel editor
5. Import the CSV, mapping:
if you're open to solutions from the Atlassian Marketplace, I think you might like JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing and inline-editing all your issue fields. You can also edit fields in bulk, using copy/paste.
To solve your exact problem, you would simply have to,
This is how this looks in action (in this example, for "Target start" and "Start date", but it would work exactly the same for your fields):
You can update any number of issues in one action.
(It's worth noting that JXL can do much more than that; from inline issue creation, to quick sorting and filtering, to support for issue hierarchies, issue grouping, and sum-ups. Disclaimer: I work on JXL :))
Hope this helps,
Best,
Hannes
Changing a field from drop down to text field isn't really possible. Others may have some suggestions but this is what I would recommend.
First, create a new field which is text. I would recommend giving this field name something unique from the existing drop down field name. Next, depending on how many choices are in your drop down field I would suggest using the bulk update to update the field.
Since I am not sure how many values you have, lets use this as an example.
Choices in drop down:
YES
NO
UNDECIDED
I would do a JQL query such as
customfieldname = YES
Next, using the bulk update select the option to edit those tickets and add YES to the new field you just created. This will only let you do 1000 rows at a time so you may need to become creative in searching through all of the issues.
Once you are done doing all of YES options, move to the next one.
Another way to do it is with scriptrunner. If you have this plug-in you can leverage the option to copy field values from one field to another based on a JQL query. You can do the same process using the JQL query to break up your choices.
Hope that helps.
-alan
As per my knowledge, out of the box this feature is not available.
You can't change the field's type (for example, making a single-select field into a multi-select field). To change a field's type, recreate the field using the desired type.
Refer below link for more details.
https://support.atlassian.com/jira-cloud-administration/docs/edit-or-delete-a-custom-field/
