How to convert multiple various numbers from one field and add them as labels
Denis November 26, 2021 edited
Hi together,
I have the following problem during creating an item (epic) from a webhook.
Trigger: Webhook
Goal: Creation of an epic
I have a field in the content of the webhook: "fieldInWebhook"
This field can have zero, one, or multiple number values.
Examples:
"fieldInWebhook":null
"fieldInWebhook":"10"
"fieldInWebhook":"10,15"
"fieldInWebhook":"10,16,18"
Each of these values have a name.
Examples:
10 = Cat0
15 = Cat5
16 = PeterPan
18 = RandomValue
If for example I get the following incoming webhook:
I want to add the labels "Cat0", "PeterPan" and "RandomValue" to the epic I create.
Question: How can I convert the Numbers to strings and split them in different labels?
any solutions?
Denis :)
November 29, 2021
Hi @Denis
Perhaps you could do this with repeated or chained replaceAll() functions on the values -> labels, and then use an advanced edit with JSON to add the values from a stored created variable.
