How to convert "next-gen" project to "classic" type
sathis kanna krishnasamy
I created the project as next-gen type. But later i realized that Subtask option is not displayed in User Story.  The current "next-gen" project has already EPICS,user stories and Sprint which is started.
Now, how can i covert the project type from  next-gen to classic?
Sathis
2 accepted
4 votes
Alexey Matveev
November 6, 2018
The only way to convert next-gen project to a classic project is to create a classic project and move all issues from the next-gen project to the this classic project.
Alexey Matveev
November 6, 2018
You would need to recreate sprints and boards.
Like mengyun.wu likes this
OK thanks Alexey
Jessica Hugghins
November 15, 2018
Do you have to move one story at a time?  I haven't found a way to bulk edit from next-gen to Classic project.
Like # people like this
Sahan Wijerama
March 7, 2019
Will it transfer all the custom fields and the links as well? @Alexey Matveev
Sahan Wijerama
March 7, 2019
Hi @Alexey Matveev
Will transfer all the custom fields and the linked tasks too?
Like andrés likes this
Alexey Matveev
March 7, 2019
It will transfer all links except epic links. It will not transfer values for custom fields, created in the project.
You can export all issues from this project to a csv file, then bulk move issues and then restore data from the csv file by using the import functionality.
Jonathan Regeimbal
December 12, 2019
Hi @Alexey Matveev ,
I've run into an issue where the Description field becomes blank during bulk move even if I check the option to "Retain".
There is also a problem with your approach.  The IDs of the moved issues will change.  How would one be able to map the correct Description to the now moved issues?
andrés
@Alexey Matveev Could you please advise on how to do the above?
kadar khan
March 3, 2021
Hi @Jonathan Regeimbal,
First you need to find the Issue ID with the help of Summary and then update the Issue ID in the csv file and then upload it. This way existing field data will come.
Kadar
Thanks Alexey. Any idea everything can be moved completely or we need to compromise few things like recreating sprint etc?
Alexey Matveev
March 7, 2019
Currently you do not need to recreate sprints. Sprints will be created for you
Like George.Bright likes this
7 votes
Patrick M
January 29, 2021
I wish I had known "next-gen" means doesn't work doesn't do anything not ready for showtime.
Ryan Smith
AGREED.
Next-gen is totally useless and now I have to migrate everything back to classic.  UGH
Deleted user July 21, 2021
Zing!
Casey Jordan
September 3, 2024
Hey Erick, which is the "classic" and which is the "next-gen" projects in this example? Are the company-wide projects next-gen or the team based projects?
I need to transfer to a classic project from a next gen and i do not know what template is considered "classic".
Harutyun
June 30, 2020
@Alexey Matveev  above you had mentioned about it "It will transfer all links except epic links. It will not transfer values for custom fields, created in the project."
I want to know about current situation. Is there any changes currently, if yes , please, let's to know.Thanks
