How to copy checkbox field values into another checkbox field?
Vincent T_ September 30, 2024
i want to copy the values from one checkbox field to another checkbox field.
I tried it with smart values, but without success. The target field gets emptied, that's it.
The source field ist named "Deployed on" .
I tried it with:
{{issue.Deployedon.value}}
{{issue.deployedon.value}}
{{issue.customfield_10226.value}}
Does it even work with smart values?
Do have other elegant solutions?
Thanks in advance.
Yash_reddy
September 30, 2024
Hi @Vincent T_
Welcome to atlassian community
Try to use Copy value functionality of Edit Issue. Click on the 3dots and select copy and select the field and issue from which it needs to be copied from.
Thanks @Yash_reddy
That works for me!
Like Yash_reddy likes this
Bandarupalli Sai
@Vincent T_  - You have to use the copy option in the edit issue action to copy the values from current issue, trigger issue ...etc based on your requirement. Refer the below screenshots
Screenshot 2024-09-30 at 1.43.18 PM.png Screenshot 2024-09-30 at 1.41.27 PM.png
Hope this helps!
