I have my scope to import csv which should create an Epic, Story and sub tasks in a single import.
Summary, Issue Type, Issue Id, Parent
First Epic, Epic, 1,
First Story, Story, 11,1
Second Story, Story, 22,1
Third Story, Story, 33,1
First sub-task, Sub-task, 111,11
Second sub-task, Sub-task, 222,11
it fails with all the possible ways i could.
I had imported separate with Epic and Story with epic link added.
Can someone help with a template that should import all in a shot.
Hi, on the parent column use the issueid instead of issuekey.
Thanks Mohan, but it didnt work and throwing this error and successfully imported creating issues in the project without any relationship
Hello Pradeep, Parent issue is already present in the site or its part of the .CSV file ?.
its already created and i had managed now with the file and imported.
thanks for your support.
Thanks Mohan
let me take a quick look at to close this thread if all works
Thanks @everyone for the help and I had it resolved. Closing this thread
If you are struggling with creating a functioning CSV template with the issues being linked correctly, and are willing to use a third-party app, you can try our app Deep Clone for Jira. You can create a template in Jira and then clone the template with Deep Clone.
Hello, Good day. Please refer to the screenshot available in https://confluence.atlassian.com/jirakb/csv-import-parent-child-mapping-1096095688.html
