How to create Cycle Time and deployment frequency reports.
Deepika.Kanaparthi
Jira has built-in Cycle Time and Deployment Frequency reports but they are empty at the moment.
We have Integrated our Jira Instance with Github and Bitbucket.  How to generate the Cycle Time and deployment frequency reports.
Valeriia_Havrylenko_SaaSJet
Hello @Deepika.Kanaparthi 👋
If you're looking add-on, you can try Time in Status for Jira developed by my SaaSJet team. Create the Cycle time report easily and display it on your board and export it to CSV or XLSX files for further analysis.
All you need is to:
  • create a status group;
  • choose statuses;
  • click the "Save" button.
Also, you can read the article which describes some ways to get the Cycle time report for your issues.
Please, let me know if you have any questions.
Hope it helps 😌
Mehmet A _Bloompeak_
Hi @Deepika.Kanaparthi
If you prefer to use a marketplace app to get cycle time reports, you can try Status Time Reports app developed by our team. It mainly provides reports and gadgets based on how much time passed in each status.
 Here is the online demo link, you can see it in action and try without installing the app. For your case, you can have a look at Cycle Time for Each Issue reports.
For further details, you can have a look at Cycle Time and Lead Time in Jira: Productivity Measurement with Two Critical Parameters article and Status Time Reports How to Videos.
  • This app has a dynamic status grouping feature so that you can generate various valuable reports as time in status, time in assignee, status entry dates and status counts, cycle time and lead time, average/sum reports by any field(e.g. average in progress time by project, average cycle time by issue creation month).
  • You can search issues by Project, Issue Type, Status, Assignee, Issue Creation/Resolution Date(and any other Date field) and JQL Query.
  • Status durations are calculated according to the working calendar you define. Once you enter your working calendar into the app, it takes your working schedule into account too. That is, "In Progress" time of an issue opened on Friday at 5 PM and closed on Monday at 9 AM, will be a few hours rather than 3 days.
  • You can set different duration formats.
  • You can export reports in CSV file format and open them in MS Excel.
  • You can also add this app as a gadget to your Jira dashboards and reach “Status Time” from Issue Detail page.
  • You can enable/disable access to Status Time reports&gadgets and Issue Detail page per project, users, groups or project role.
If you are looking for a completely free solution, you can try the limited version Status Time Reports Free.
Hope it helps.
Amay Purohit_RVS
January 11, 2024
If you are open to try out a mktplace solution, to get this data you can try out our app.
Time in Status Reports
The add-on provides 20+ reports. You can also group your statuses to define your own cycle / resolution times.
The app is free upto 10 users
Disclaimer : I work for the vendor who built this app
Danut M _StonikByte_
January 9, 2024 edited
Hi @Deepika.Kanaparthi,
One possible way is to use the gadgets offered by our Great Gadgets plugin.
But for this reports/charts to work, there should be a ticket in Jira of type "Deployment" for each deployment performed in production. So if you can manage to create such tickets manually or automatically, you could generate reports like this.
The chart above if generated by using the Kanban Velocity gadget offered by our plugin.
The same plugin offers some gadget for measuring Cycle Time. Here is an example of Cycle Time Trend Chart gadget that shows average cycle time for last months and its trend.
image.png For measuring cycle time you can also use Control Chart gadget and Histogram Chart gadget.
Hope this helps. If you have any questions about these gadgets, please contact support@stonikbyte.com.
Thank you,
Danut Manda
Gizem Gökçe _OBSS_
Hello @Deepika.Kanaparthi ,
If you are ok to use a marketplace app for your reports, Timepiece - Time in Status for Jira which is developed by my team at OBSS, is the tool I would highly recommend. It is available for both Jira Cloud and Data Center.
Time in Status mainly allows you to see how much time each issue spent on each status or each assigneeYou can combine the time for multiple statuses to get metrics like Issue Age, Cycle Time, Lead Time, Resolution Time etc. (Please see the screenshot below)
For all numeric report types, you can also calculate averages and sums of those durations grouped by the issue fields you select. For example total in-progress time per customer or average resolution time per sprint, week, month, issuetype, request type, etc. The ability to group by parts of dates (year, month, week, day, hour) or sprints is particularly useful here since it allows you to compare different time periods or see the trend.
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well.
Time in Status reports can be accessed through its own reporting page, dashboard gadgets, and issue view screen tabs. All these options can provide both calculated data tables and charts. And the app has a REST API so you can get the reports from Jira UI or via REST. Also you can export the reports in to various formats easily.
Visit Timepiece - Time in Status for Jira to explore how our JIRA add-on can revolutionize your metrics measurement process. Enjoy a 30-day free trial to experience the full range of features.
If you wish, you can also schedule a live demo. We will provide a comprehensive overview of the application and address any inquiries you may have.
Hope it helps,
Gizem
