Listener
import com.atlassian.event.api.EventListener;
import com.atlassian.event.api.EventPublisher;
import com.atlassian.jira.event.issue.IssueEvent;
import org.springframework.beans.factory.DisposableBean;
import org.springframework.beans.factory.InitializingBean;
public class Listener implements InitializingBean, DisposableBean { private final EventPublisher eventPublisher; public Listener(EventPublisher eventPublisher) { this.eventPublisher = eventPublisher; } @Override public void afterPropertiesSet() throws Exception { eventPublisher.register(this); } @Override public void destroy() throws Exception { eventPublisher.unregister(this); } @EventListener public void onIssueEvent(IssueEvent issueEvent) { if (Objects.equals(issueEvent.getEventTypeId(), EventType.ISSUE_CREATED_ID)) { // some code } } }
and to atlassian-plugin.xml
<atlassian-plugin> ........ <component key="eventListener" class="Listener"> <description>Class that processes the incoming JIRA issue events.</description> </component> ........ </atlassian-plugin>
Hello All,
How can I have a event for component created in specific project? I only find issue_created, issue_updated etc i.e with the issues.
How about for components and versions which are project specific.
Naveen
