How to create a custom field value based on another custom field selection
Marcin Jankielewicz February 22, 2021
I'm trying to setup a new custom field with 2 selections from which you can chose either one or both.
If first one is selected I would like for new custom field to show specific values
and if second is selected I would like for that same custom field to show different values
but if both are selected, then I'd like for combined values to show in the new custom field.
Is there a way to do this?  If so, what's the most efficient way?
Thank you.
John Funk
Hi Marcin - Welcome to the Atlassian Community!
You could consider using a custom field with cascading values type, but that won't work if you want the first field to have multiple selections in it.
The only way in Jira Cloud to come close to that would be to use a third party add-on such as ProForma Forms.
Marcin Jankielewicz February 23, 2021
Hi John,
Thank you for your prompt suggestion.
I used cascading value type for now so that only 1 selection can be made.
I'll look into ProForma Forms and see how useful will that be.
Thanks again.
Like • 2 people like this
