How to create a new log file for values in Jira
Mouna Hammoudi
September 29, 2022
I am current using the following code for my Jira plugin, it is a fragment with a REST endpoint. Here is the code for my REST endpoint below:
import groovy.json.JsonBuilder
import groovy.transform.BaseScript
import com.atlassian.jira.issue.Issue;
import javax.ws.rs.core.Response
import org.apache.log4j.Logger
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import javax.ws.rs.core.MultivaluedMap
import com.onresolve.scriptrunner.runner.ScriptRunnerImpl
import com.atlassian.sal.api.ApplicationProperties
import com.atlassian.sal.api.UrlMode
import Helper
@BaseScript CustomEndpointDelegate delegate
def log = Logger.getLogger("atlassian-jira.log")
def bulkSplitterHashMap= Helper.getBulkSplitterHashMap()
int iTracSuperFeatureSplitterIssueTypeID = bulkSplitterHashMap["iTracSuperFeatureSplitterIssueTypeID"] ;
int iTracSuperFeatureSplitterProjectID = bulkSplitterHashMap["iTracSuperFeatureSplitterProjectID"] ;
String iTracSuperFeatureSplitterURL =bulkSplitterHashMap["iTracSuperFeatureSplitterURL"];
callBulkSplitter(httpMethod: "GET", groups: ["jira-users"]) {
MultivaluedMap queryParams, String body ->
def user = ComponentAccessor.jiraAuthenticationContext?.loggedInUser
def issueId = queryParams.getFirst("issueId") as Long
Issue myissue = ComponentAccessor.getIssueManager().getIssueObject(issueId)
def issueKey = myissue.getKey()
def project = myissue.getProject()
def baseUrl = ScriptRunnerImpl.getOsgiService(ApplicationProperties).getBaseUrl(UrlMode.ABSOLUTE)
def iTracSuperFeatureSplitterURL2 = iTracSuperFeatureSplitterURL.replaceAll(":1:", issueKey)
def iTracSuperFeatureSplitterURL3 = iTracSuperFeatureSplitterURL2.replaceAll(":2:", user.getUsername())
def projectID = project.get("id")
int projectIDInt = projectID as int
if (iTracSuperFeatureSplitterProjectID == projectIDInt && iTracSuperFeatureSplitterIssueTypeID == Long.valueOf(myissue.getIssueTypeId())) {
log.warn("The rest endpoint has been executed by the user " +user)
Response.temporaryRedirect(URI.create(iTracSuperFeatureSplitterURL3)).build()
I am using the following statement to log some values for testing:
I am also using this statement for printing the values that I would like to test:
I would like to use a new log called **itrac-pulgins** and I tried simply replacing the line **`def log = Logger.getLogger("atlassian-jira.log")`** with **`def log = Logger.getLogger("itrac-plugins.log")`** but it didn't work. How can I create a new log called **itrac-pulgins** where I can print my debugging statements?
Craig Nodwell
Check Using your own log4j configuration for your plugin 344 documentation.
The answer to this similar
developer community question 141 might also help you out.
Register here ⬇️
