How to create a new project department in Jira?
Carol Rodriguez
Hi there,
I am trying to create a new project department, in which I can charge hours. The new project department should appear as an option in the page of Create New Issue.
I show it as follow:
Thanks so much!
Martin Bayer _MoroSystems_ s_r_o__
Hi @Carol Rodriguez I probably do not understand the problem, sorry :).
If you need to add the option to the field, you have to go to the field's configuration... attaching screenshots of how to do it step by step:
Carol Rodriguez
Thank you so much Martin!; has been very very useful!!!! I got the answer that i needed
