×We're working to connect xMatters to our Jira instance and we've come into an issue with needing an account with basic authentication. The problem is that we use SSO, so we'd need to make an account that has a username and password and I don't see that option anywhere. Would really appreciate some help. Thanks!
Hi @Jonathan Do ,
If I understand correctly you have SSO enabled and you need credentials to integrate with a third party tool (xMatters).
If this is the case, you will have to use an Atlassian account email address and API token as username and password.
In order to do so:
In case this is not what you are trying to do, please provide more details.
Dario
Hi Dario,
That did it! If you don't mind me asking, where did you find this? It's something we might try to do again with other services so it'd be great if I could get a better understanding of how Jira interacts with various integrations.
Hi @Jonathan Do ,
The possibility to use basic authentication with username and password has been removed since June 2019, you can review the below link for more details:
As of June 2019, Atlassian Cloud users who are using a REST endpoint in Jira or Confluence Cloud with basic or cookie-based authentication will need to update their app or integration processes to use an API token, OAuth, or Atlassian Connect.
Learn more about basic auth for REST APIs in Jira and Confluence Cloud.
Also, if you want to get a better understanding on how Jira interacts/integrates with other applications, please look at the below pages
I hope this helps.
Dario
