How to create sprint above existing sprint in backlog?
Simon Heinen
September 5, 2018
In summary I want to do this:pleaseLetMeDoThis.png
This would help a lot when inserting a new sprint in between existing sprints
Gabriele Franck
September 6, 2018 edited
Hi @Simon Heinen
Although you don't have the Create sprint above feature, you do have the Move sprint down and Move sprint up features, which allow you to achieve exact the same thing that is reorganising the scheduling of your sprints.
The only difference is that, first, you need to create a new sprint and then you can move it up/down.
Let me know if this helps! :)
CJ January 16, 2019
Hi Simon,
If you'd find it useful to drag and drop sprints in the backlog (the 'move sprint up/down' can be a bit slow), you can vote for the feature request:
* Cloud: https://jira.atlassian.com/browse/JRACLOUD-64086
* Server: https://jira.atlassian.com/browse/JRASERVER-64086
Warren
September 5, 2018
Hi Simon
To me this isn't a question, but more a feature request. If so, you'll need to raise this as a support request with Atlassian, I don't think this is the correct forum for this.
Unless ... there is an add-on out there that will do this, but that's outside my remit
