How to created date field to display a specific date
James Lebron
Hi.here
I want the created date field provided by the system to show a specific time, instead of showing like a few hours ago,
What should I do please?
Bharathi
August 10, 2022
Hi @James Lebron,
If your instance is a server/data center, you can make this change by following the KB @ Display standard dates in Jira server | Jira | Atlassian Documentation.
Hope this helps!
Abdelrahman R August 10, 2022 edited
Hello @James Lebron ,
I hope you are well today.
You can use the below:
AND created >= 2022-07-14 AND created <= 2022-08-11 ORDER BY created ASC
That would retrieve the cases from 14-july to 11-August.
- You can change the dates according to your needs.
I hope that would help.
Let's build A Rovo Agent 🤖
Save your spot
