I have structure which has list of stories, few belongs to component A, few to component A and B, and some more to Component A, B and C.
Is there a way i can group specific to component because when i select group by filter it shows all the combinations of components and groups it. How do I limit it to only one particular component.
Hi Praveen,
Could you please elaborate more, perhaps using a screenshot of the behavior you are encountering and would like to change.
Awaiting your return,
Karim
@Parveen Taj No worries, Parveen. As @David Niro indicated that this is a feature they are currently considering in their backlog, I could meanwhile propose an alternative using JIRA Native features to achieve your structure.
This solution will be easy to implement if you have few components.
Steps
Pro-Tips
Karim
Hi @Karim ABO HASHISH ! I believe that @Parveen Taj may be using our product, Structure - Flexible Jira Project Management.
@Parveen Taj , if I have this right, it is not possible to do at the moment. However, we do have a feature in our backlog that would allow us to do something like this in the future. Please let me know if you are referring to Structure and I will add your vote to the task.
Best,
David
