×I have taken over this project template created from someone who has now left the organization. I see customer menu in my project settings and bunch of e-mails registered as customers. I want to delete all these customers and make a fresh start. Can i do so ?
I tried to search for customer delete option, however same is not available and need help.
Hi, @Sachin Deodhar Welcome to the community!
do you use a cloud or server platform?
In the cloud you can go to project > project settings > People > and click Remove on the customer.
if you want to deactivate the customer altogether your System Admin can do so as follows: jira settings > User management > Jira Service Desk > locate the user and deactivate.
I hope it will help.
I checked above however it doesns allow me to delete customer accounts. from above.
Instead I could find my way to delete same from admin console
So in admin, i checked for jira service desk and it showed 'Portal Customer' screen, where i can delete customers. Only pain is i need to do it one by one.
Ofcourse, one by one delete is 'by design'. Dont think, there should be a check-box to delete bulk users unless you are terminating the entire team. One should be careful when deleting a user, because on an accidental delete, you might have to restore all his 'roles' as well. This becomes cumbersome when u do bulk delete!!
