On your cloud site, go to Administration> Billing > Manage subscriptions. Look for the product you want to reset (Jira or Confluence), select the 3 dots for more options, and then select Delete. Enter the word DELETE into the field.
Hello @Avyukt M,
The steps you mentioned are for removing a product from a site, but not to delete an entire site.
If you want to delete a site, you must cancel its subscription.
Go to Cog icon > Billing > Manage subscriptions > Cancel subscriptions.
For more details, please check the documentation below:
Angélica
Thanks. I guess i have created 2 accounts and that was where the mixup came from. however, i have deleted the account now.
Can I open a new account?
same problem how to delete the accounts
Use these steps if you have at least two different products on your cloud site (for example Confluence and Jira, Jira and Opsgenie, or Confluence and Opsgenie). If you have more than one Jira product, they count as one.
You can choose to only reset one product or you can reset both. If you want to reset both, you will need to do it one at a time.
Can I just email atlassian somehow and state some folks created a new confluence or jira and have them delete it for me? I can see that through my Atlassian Admin and they are having issues trying to figure out how to remove.
