How to delete or merge the columns of board view in jira work management projects?
Hi Shivani,
In a JWM project board, the columns are determined by the workflow(s) you have set for the issues.
To delete or merge two columns, move all the issues from the column you want rid of into the status that the column you want to keep represents, and then remove the unwanted status from the workflow.
Hey @shivani shirguppi ,
Are you in a team-managed or company-managed project? And what is the level of access you have?
George
