How to delete subtasks in next-gen projects?
Sima Jamshidi August 20, 2019
Our team is using a next-gen project for the first time. We had the situation that we wanted to delete several subtasks from a story but could not find how to do it. How is it possible? The only options we found were moving the subtask to a different story. Or changing the issue type from subtask to something different.
Krister Broman _Advania_
August 20, 2019
And i presume you are trying to delete the issue with a user that is administrator of that project? Only admins have Delete permissions in next gen projects.
https://confluence.atlassian.com/jirasoftwarecloud/overview-of-permissions-in-next-gen-projects-959283605.html
Then it should not be an issue just press menu
Thanks for your help! :) Issue solved.
August 20, 2019
Great, please also mark the answer as accepted, it helps everyone :-)
Thanks for your help. :) Issue solved.
