How to delete the duplicate workflow scheme?
Max
I mistakenly created the Workflow duplicate scheme, but I can't delete one of the copies.
Could you help with it?
2 accepted
5 votes
Fadoua
November 16, 2024
@Max
Make sure that your workflow is not linked on any issue type then you be able to delete it
Best,
Fadoua
Max
@Fadoua Hi! Thank you for the reply!
Workflow is not linked. but I still can't find the way to delete it)
It should be super easy but I can't find the way  to do it)
Fadoua
November 16, 2024
Can you please send a screenshot from the project it is showing under?
Like • Max likes this
Max
@Fadoua Sure
Fadoua
November 17, 2024
Ok it makes sense @Max the simplified workflow that is active in the project is linked to the copy2 workflow scheme. You project active workflows should be linked back to copy1.
Do you know how to take care of it?
we may need to hop on a call if you are ok with it.
Max
@Fadoua Thank you for your advice. I'll get back after a few days and will try to do it without any help, in the first place. It helps me to learn more info :)
But it could be I'll mention you here in case I cannot find the way :)
It seems it is not as obvious as it was expected in my mind :)
I truly appreciate your time ^_^
It's cool to get some support in such basic-level settings, let alone the sophisticated one
Fadoua
November 17, 2024
I totally understand you @Max
If you have any question, please ping me here.
Thank you for accepting my answer!
Best,
Fadoua
3 votes
Jehan Bhathena
November 17, 2024
Hi @Max
Please can you share a snapshot of the Workflow Scheme settings?
From the snapshot from your question, the image shows the workflow settings, and it is linked is linked to an Project.
You can reference this thread to get more info https://community.atlassian.com/t5/Jira-questions/Re-Delete-workflow-scheme/qaq-p/1440663/comment-id/436677#M436677
But long story short :-), your Workflow scheme needs to be inactive in order to be deletable.
Max
For those beginners who need some navigation info:
Fadoua
November 17, 2024
@Max  Yes there are both Inactive workflow Schemes and Inactive Workflows. When you remove some workflow schemes you may see more inactive workflows.
Best of luck!
