How to disable create branch link in selective Jira tickets ?
Dineshmathiazhagan April 21, 2021
We have two types of Jira tickets example task and subtask - we see the create branch hyperlink available in both task and subtask Jira forms how do we enable this link only in sub task and not in parent task
Note - create branch hyperlink which helps in creating the feature branch using bitbucket branch from Jira
Andreas Link May 5, 2022
Yes, you can, I have solved this.
Solution is to have a dedicated workflow for your tasks not being subtasks (as usual) and on each state of that issue workflow you set the property...
jira.permission.viewversioncontrol.denied
...and that's it. Then the development tools are not visible in any of the states anymore, but can still be seen/used on underlying issues with another workflow.
Sourcehttps://support.atlassian.com/jira-cloud-administration/docs/use-workflow-properties/
atlassian, state of product 2026, product teams report, developer experience, product manager survey, AI impact, product team stress, product teamwork, dev workflow insights, 1000+ PMs, product leadership research
State of Product 2026
State of Product 2026: your pulse check on product development today. We asked 1000+ real teams how they’re feeling–and they had a lot to say.
Get the report
