How to disable jira mobile app?
Redworld June 4, 2020 edited
Which plugin I need to disable?
jira mobile
Mobile plugin for jira
What is the use of each plugin?
Nir Haimov
Hi @Redworld
Are you using Jira Server or Cloud?
Also, please expend each plugin and tell which company belong to each one of the plugins
I am using Jira server. 8.7.1.
Please find the app details.
I like to know about both apps. Both are system apps and belongs to atlassian
Nir Haimov
So there is no bot app, all are legit Atlassian apps.
All you want to do is disable the feature so users will not be able to use Jira through their mobile?
yes. Also like to know the difference between the apps. why two apps?
Nir Haimov
it doesn't really matters why there are 2 apps, but basically they are depends on each other, one is the rest resources and the other holds the main code and logic.
Now, if all you want is to disable the mobile feature.
disable the plugin called " Jira mobile"
Redworld June 5, 2020
but still able to connect. Do I need to disable other one too?
Nir Haimov
strange... not should be able to connect, try to disable the second too.
Redworld June 8, 2020 edited
works when I disable "Mobile Plugin for Jira". Seems mobile app depends only on this plugin.
Nir Haimov
so the problem solved?
if so, please mark this as the answer for your ticket so it will marked as closed.
Register now
