How to display a custom issue in a Project's Road Map
Akira Tsuchiya
March 5, 2012
I want to know what I should do for displaying a custom issue in a Project's Road Map.
1. A custom Field Configuration Scheme is applied so that a Task issue is created in a custom Field Configuration.
2. The Version Picker of 'Milestone' is defined in the 'Create Issue' screen.
3. The created Task issue is not displayed in the Project's Road Map.
Akira Tsuchiya
March 6, 2012
Now I ask the question from a different angle.
In the Default Field Configuration, 'Fix Version/s' is related to the Road Map while 'Affects Version/s' is not.
What is the difference between them?
If it becomes clear, I may configure so that a custom Version Picker is related to Road Map.
