×How to dynamically fill in the Sub Component custom field to be a dynamic select list of values dependent on value of component?
EXAMPLE
Component: values are Comp X, Comp Y, Comp Z
Now for Comp X
Sub Component values are A, B, C
Now for Comp Y
Sub Component values are N, O, P
Now for Comp Z
Sub Component values are Q, R, S
So when the user selects Comp X as the component I want the Sub Component field to have a select list containing values A B C
How can this be achieved?
Sebastien
Jira supports only one level of component. If you need to have this sub-levels you can use a custom field (Multi Level Select) and give the components in that. But remember, you will lose some standard functionality offered by Jira if you use a custom field. For Jira it is just another field.
Some more discussions in this thread https://answers.atlassian.com/questions/28902/breaking-down-components
