How to enable create subtask option at beside workflow transition
Musku Nagaraju
November 27, 2019 edited
Hi Team,
I am using JIRA server, and we mostly create subtasks with using create-subtask option in more,
and our subtask name "candidate", I need to create Candidate option beside workflow transitions, when I click on it I need to get subtask create screen and i need to able to create subtask with in the same issue.
Attached example screen shot.
Jimmy Seddon
Hi @Musku Nagaraju,
This is not something that is available out of the box, and given the custom nature of what you are looking for I'm not sure that you are going to be able to find an app in the Marketplace that will achieve what you are looking for, though it can't hurt to take a look.
For what you want to achieve you are going to need to write something custom.  That means either writing something using the plugin SDK in Java your self, and you can get started with that here:
https://developer.atlassian.com/server/framework/atlassian-sdk/set-up-the-atlassian-plugin-sdk-and-build-a-project/
Or engaging with an Atlassian solution partner to build it for you.  You can locate someone near you here:
https://partnerdirectory.atlassian.com/
I hope that helps!
-Jimmy
Musku Nagaraju
Hi Team,
Any update on this?
