Hi @jebymathew,
Hello! I have activate the check 'parallel sprints' but doesn't work...Can you help me please? Thanks!
@Barbara Escobar We're having the same issue. We check the "parallel sprints" option, but it doesn't save. In fact none of the changes on the Jira Software Configuration screen save: if I uncheck an option that's checked, then go to another screen & come back, the option is checked again. Is that similar to what's happening for you?
@Dave Sampson have you managed to resolve the issue
Read the story
